84 Camaro Idles way above 2000 at start up
Old 04-04-2012, 08:43 PM
bizzmzn's Avatar
Default 84 Camaro Idles way above 2000 at start up
I just got my 84 camaro z28 to start and when I did the rpm's jumped to well above acceptable levels and was spewing white smoke out of the exhaust pipe. I have installed a new carb and many other new parts. I was wondering if anybody else has had this problem. plus i was wondering if any of the vacuum lines had to be hooked up because the previous owner cut and capped off all of the vacuum lines. Thank you in advance for all your help
Old 04-07-2012, 07:37 PM
djs383's Avatar
To start with, are you sure its idling high, and it isn't just a bad tach? You should be able to tell and adjust from there. After seeing you just installed a new carb i'm thinking that could be a place to look. 2nd, yes those vacuum lines were put there for a reason, not knowing what induction was originally on the car hurts my guessing, but some of that would be for vacuum for heater vents, vacuum advance (if thats what dizzy was there)....etc.. White smoke signals coolant entering in the combustion chamber which could be a few different things, bad head gasket, cracked/warped head, cracked block. Too tough to guess until you dig in a little more. By the way, if that was originally a Q-jet replacing it with a non computer controlled carb is going to make a few problems. Let us know exactly what you had to begin with.
The Emperor
82-92 V6 Tech
11
09-16-2013 06:30 PM
saylor
07-03-2013 11:21 PM
Reverend Bull
10-06-2012 12:22 AM
adkins
09-24-2010 08:42 PM
Jocam
12-30-2009 05:58 PM
Quick Reply: 84 Camaro Idles way above 2000 at start up
