1989 Camaro RS Steering Column Repair - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
LinkBack Thread Tools Search this Thread
Old 05-25-2008, 02:59 PM
Default 1989 Camaro RS Steering Column Repair
Hello All,
I have a 1989 RS with a tilt-column in need of repair, due to an attempted auto theft...
basically, the collar on the back side of the column is all busted up as is the housing in front of it that holds the ignition switch, signals, etc...
I bought one of the haynes manuals from autozone but it appears to be taking to many things for granted about what one needs to know about disassembling the column down to this level...
I did a bunch of googling and found a few how to's for other columns but still not enough info to help me get mine disassembled far enough to replace those two collars and whatever else is jacked up on the inside...
A couple of those links let me to this forum, but none appeared to go that deep either...
I have managed to get past using the steering lock plate puller etc, I have the ignition switch removed, but I can not seem to get the rest of it disassembled far enough to get to the busted out plastic collar on the back of the column...
anybody have any how to links or photos of how to get this dang thing apart? on these 3rd generation camaros, without the airbag in the column?
Thanks in advance.
Old 05-25-2008, 05:49 PM
Default RE: 1989 Camaro RS Steering Column Repair
I could explain it too you and give you all my tricks I have come up with but this should be much more clear than how I can explain it.
http://elcaminocentral.com/article95.html
Of course while you have it apart go far enough to make sure the four torx bolts that are comon to come loose are tight. that hold the last part of the tilt area
Old 05-26-2008, 02:20 AM
Jr. Mechanic's Avatar
August 2009 ROTM
In all honesty, it is MUCH easier just to stick a new column in there. You can get one fairly cheap from the junk yard or online and you can stick it in there in no time.
Old 12-28-2008, 10:47 PM
took me five minutes to replace mine i will have to tell you that i had to cut the wires that went to the white trn signal thing and the wiper thing the tilt stick unscrews and you take out the 3 torq screws then it slides off had to splice them when i put a new plastic column on got it at the junk yard for free dixiemontiecarlo wanted like $70 hope this helps
Reply
Thread Thread Starter Forum Replies Last Post
02 steering wheel and column in 96 camaro the R. 93-02 General 10 05-17-2012 07:04 AM
1989 camaro steering column szpilafam 82-92 General 0 10-28-2011 07:34 AM
Firebird steering column in a Camaro ryguy425425 93-02 General 1 04-07-2010 06:40 PM
75 Camaro Steering Column Needed 75camaroguy 70-81 General 0 02-10-2009 12:56 PM
Tags
1989, 3rd, 89, busted, camaro, colum, column, columns, dismantle, fix, gen, inside, loose, repair, rs, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
