resonated tip?
RE: resonated tip?
It's like a mini "straight thru" muffler, with baffles cut into the inner portion of it, and some could also be fiberglass packed. They're designed to take the "rap" out of your exhaust note. And they do work.
RE: resonated tip?
yeah fart cans are massive and obnoxious. resonated tips can range in all sizes and "resonate" the tone of your exhaust. on a v-8 or v-6 they will give it a cleaner sounding tone and take away the brap when you give it full throttle up in the revs. look at the slp loudmouth exhaust system and listen to a sound clip. that system doesnt use a muffler, it uses a good size resonator in the cat-back pipe.
