Single or double roller timing chain
Old 09-12-2010, 12:57 AM
1976camaro's Avatar
Default Single or double roller timing chain
What is the Difference between a single roller timing chain and a double roller timing chain i got a 1976 chevy camaro 305 and i need a new timing chain and gears what is the difference between a single and double roller
Old 09-28-2010, 01:21 PM
my71baby's Avatar
I'm a little surprised nobody got back to you on this. I just replaced the timing chain on my '71, let me say "I know very little about cars", aside from that I had some help from my uncle, who knows a lot more than I do. He said definitely go with the double roller, so I did. The difference is hard to put into words exactly, other than its literally two chains instead of just one. I'm guessing by now you've gone to the auto parts store and looked at the difference. From what I understand the double roller is much stronger and will last longer.
Old 09-28-2010, 05:36 PM
^ Because this was a duplicate question that was already responded to in a different thread he had:
https://camaroforums.com/forum/showt...t=54758&page=4
Old 09-29-2010, 02:21 PM
1976camaro's Avatar
I had actually gotten just a single roller set for now beacsue i plan on gettin a new 305 HO engine so i didnt really wanna put alot into it right now im already going with a new exhuast that can be put on both engines im getting hooker comp headers 2 flomaster 40 series and an X pipe
Old 09-29-2010, 10:22 PM
1976camaro's Avatar
Old 09-29-2010, 10:25 PM
1976camaro's Avatar
http://www.myyearbook.com/?mysession...Q9NzM1OTU4MA==
go here to see the pic of the chain and gears
Old 09-29-2010, 11:34 PM
Oh wow, that's pretty bad. Did you get out all the broken pieces?
Old 09-30-2010, 11:17 AM
my71baby's Avatar
WOW that was pretty bad! I'm surprised it can even get that worn and still work at all. I'm gonna go with, changing it was probably a good idea
Old 10-01-2010, 01:09 PM
1976camaro's Avatar
ya i got the broken peices out and ya im surprised it ran also getting the crank gear on though was a pain...i got the gears on now tryin to get the chain on right is hard since i still ahve the engine in the car and getting the harmonic balancer back on with out stripping the crank threads will be hard also...I wish one of you guys lived close to me so you can help haha
Old 10-01-2010, 01:32 PM
DO NOT, DO NOT, DO NOT drive the harmonic damper on using your crank bolt. Use the proper installation tool, and you won't damage the threads. Autozone will loan the tool out to you.
http://www.autozone.com/autozone/cat...oductId=391373
Quick Reply: Single or double roller timing chain
