How can I tell if my distributor/timing is off?
Old 08-01-2010, 02:24 AM
Dustinho's Avatar
Default How can I tell if my distributor/timing is off?
I just put in a 350 in my 77 and am trying to figure out what to do. When I get on my motor it starts to ping (rattle noise) above 45 mph. Also when I shut the car off it will studder when engine is shut off. And it only does this when the motor is warmed up.
My father changed the distributor position when he replaced the tranny one or two clicks but can't quite remember the exact amount. He moved it back but I still think it's all off still.
Can anyone confirm that this sounds like the timing is off and there is a problem with distributor position?
I hope this make sense. Thanks!
Old 08-01-2010, 09:31 AM
Y2K's Avatar
Y2K
Y2K is offline
Old 08-01-2010, 08:37 PM
80ZJoe's Avatar
July 2010 ROTM
When it's hot can you start your car up right after you shut it off?
Old 08-01-2010, 09:41 PM
Try using a timing light, then you will know what you got.
Old 08-03-2010, 12:20 AM
Dustinho's Avatar
Yes...not right up but will crank a few seconds then start.
Dustinho's Avatar
It's very hard to read the markings.
Old 08-03-2010, 12:22 AM
Dustinho's Avatar
I just need to figure out where rotor cap should be when pointing on TDC.
ScottD
03-18-2010 12:36 AM
sewerrat
82-92 V8 Tech
06-26-2009 12:59 AM
1979RS
70-81 V8 Tech
12-23-2008 07:16 PM
Isphius
82-92 V8 Tech
01-14-2008 11:14 PM
btrux06
12-03-2004 08:27 AM
Quick Reply: How can I tell if my distributor/timing is off?
