Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Vendor Threads | New Picture Comments | New Profile Comments |
Search:
Go Back   Camaro Forums - Chevy Camaro Enthusiast Forum > 2nd Generation (1970-1981) > 70-81 Drivetrain > 70-81 Transmission & Differential
Sign in using an external account
Register Forgot Password?
Reply
LinkBack Thread Tools Search this Thread
Old 04-26-2012, 09:57 PM
No cars in Dave81Z's garage, add now
Default th350 broken ear
I was putting the motor back in my camaro today and when i was tightening the bellhousing bolt the ear cracked off. It's the one on the drivers side above the alignment pin hole. It was a clean break and the rest of the housing seems ok is it possible to run without that bolt or do i need to get the ear welded back on. Thanks.
Old 04-27-2012, 12:56 AM
oldman9's Avatar
1976 Chevrolet Camaro
I'd make some calls to some of the shops around your area and see if some one could do an onsite weld for a reasonable price. If something broke and we just overlooked it until the part failed....
We would all drive hondas with fart-cans....
The worst you might haft to do is pull the engine back out and lower your trans a bit.
__________________
Old 04-27-2012, 01:35 PM
I was actually bolting them together out of the car I got ahead of myself and didnt realize it was in a bind til it was too late. I'm picking up another th350 today and going to take it the other and get fixed and keep it as a spare.
Old 04-27-2012, 05:32 PM
camaros4evr's Avatar
1973 Chevrolet Camaro
I had that happen to me too, its most likely cause the converter wasn't pushed all the way in, we just took the trans to a welding shop and had the guy weld the tab back on. Double check that converter, it has to push in twice, push and turn it, you'll feel it move on the input shaft, then turn it some more and you'll feel it bottom out, you should be golden then. good luck
Activity Stream
Search:
Reply
Tags
broken, cracked, ear, ears, th350
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
