saginaw 4 speed vs t5
Old 03-19-2015, 12:52 AM
greencamaro1981's Avatar
Default saginaw 4 speed vs t5
so what are the torque rating numbers on each? i have a fairly stock 305 (cam headers intake) in my car and now i will have to keep it there but will a t5 die instantly i thought they had omparable torque ratins and i dont thrash on it much
Old 03-19-2015, 09:51 AM
Depends on which T5 you buy. All T5's are not made equal. A world class T5 is much stronger than a V6 T5. If you get a T5 from a V8 it is rated around 300 ft. lbs., and with an upgrade kit it can be boosted to over 350 ft. lbs., but then you're getting into T56 prices. A 305 V8 is rated around 250 ft. lbs., so a T5 from a V8 should hold up, unless you got big stickly tires, and did a lot of clutch dumps.
The Saginaw was a budget 4 speed that went in pretty mild cars. It wont be any better torque rating than the T5. Almost all the other Muncie, and Borg Warner 4 speeds have higher torque ratings, and the Super T10, and Muncie M22 have much higher torque ratings compared to standard T10 and M20, M21 4 speeds. I wouldn't waste my time putting a Saginaw 4 speed in my car, even if it was free. At least a T5 will be equal rating, but give a 5th gear OD.
Old 03-19-2015, 07:08 PM
thats what i thought i have the option to get a t5 wc for a few hundred with everything but a shifter i might try and get it in there
Old 03-20-2015, 09:57 AM
That's a very good price if it's in great shape! I don't se WC T5's under $500 around here. A shifter is easy, and cheap, unless you got an exotic shifter.
Carkid70
70-81 Transmission & Differential
05-08-2011 08:14 PM
mainejohn
03-03-2011 12:22 PM
Rroxon
04-12-2009 12:44 AM
jwalsh66
03-05-2009 07:53 PM
Edog
67-69 V8 Tech
12
12-26-2008 08:44 PM
Quick Reply: saginaw 4 speed vs t5
