Help with full suspension....
I have a 1981 z28. Now don't get me wrong it's fun to go down the strip, but i like the track. I am not getting as much from my suspension as i would like. The back slips out a little i have noticed. I want to upgrade the suspension all the way through. But! my funds are limited right now. So where should i start. I want to buy the parts that will make the most difference first. and then the smaller parts. i checked for worn parts already. suprisingly nothing is to to bad.
Try going to 1 1/4 front and 7/8 rear sway bars (Factory are 1 1/8 and 3/4 rear),with a Herb Adams/Moroso rear bar brackets.(Its a better and stronger design and easier to find bushings for) with greaseable poly bushings.This is the basic upgrade I have done to my 1979 Z-28 RS Camaro Pro-touring car. And still use even with Vette Brakes C-4 Corvette adjustable front suspension. Because it tightens the car ,and it is something you can do as you have the time and the money to do so.Good luck to you.
