Front springs 1980 Z28 f41 suspension
Old 12-22-2014, 04:17 PM
keefer80z28's Avatar
Default Front springs 1980 Z28 f41 suspension
There seems to be many springs on line that come up when i punch in the car. Starting to get confused, so far Eaton part number 1412 seems to be the one I need but would like to buy locally in case I get the wrong spring. Moog #6486 comes up but seems to be a fit for all models and I would think the heavy duty suspension would be different. Someone here mentioned Global West # c-7412-282 but went to the website and no longer available. I am just going to cruise in the car so dont need anything special but dont want to go cheap and regret it later. Can anyone recommend what i should be installing. Thanks for your reply, this is my first kinda put the car back together project. 350 engine
Old 12-23-2014, 12:23 AM
greencamaro1981's Avatar
just go with the springs that are recomended the 6486 will be a great stock replacement but remember the new spring will ride high for a few years before settling downalso what engine do you have? aluminum heads will factor heavily into the ride height
Old 12-23-2014, 10:24 AM
Thanks for the reply, no aluminum heads stock 350. Not sure if it matters but no ac. Thanks again, Keith
Old 12-24-2014, 09:13 AM
The HD F41 suspension is a different spring. It's a bit stiffer than the standard Camaro spring. But it's not different than the HD spring spec'd for the standard Camaro with AC. I ordered the HD spring for a car with 350 and AC for mine, and they worked great to replace my F41 springs. Moog 580. As mentioned, a bit higher stance when new.
Carid has them for $23 ea. on Ebay.
http://www.ebay.com/itm/MOOG-580-Fro...404439&vxp=mtr
Old 12-28-2014, 02:24 PM
Thank You, I will go with the 580
cozen89
04-11-2015 12:34 PM
Gorn
02-03-2012 06:37 AM
1980Z28RustBucket
06-28-2010 04:18 PM
1980z
70-81 V8 Tech
03-05-2010 11:00 AM
nscfn8
12-11-2006 03:24 PM
Quick Reply: Front springs 1980 Z28 f41 suspension
