2nd generation coil spring spacer
Old 02-06-2016, 11:08 PM
my69camaro's Avatar
Default 2nd generation coil spring spacer
I have a few questions to ask the members. I have a hot rod truck with a 2nd generation camaro front suspension and recently have installed a BBC. I'm having an issue with the front tires hitting the fenders when I turn and am needing to space the body up higher from the tires. the 1st question i have is how would I find out if I had coil springs for a big block? I've put in rubber coil spring spacers IN the coils but haven't gotten much improvement. I need about 1" more for clearance. The 2nd question I have is is there a better way to increase the body height? What would you suggest. NO I'm not drag racing, merely a street cruiser. thank you.
Old 02-07-2016, 05:04 PM
80sz's Avatar
You could get some coil spring spacers, They are Aluminum and go under the coil spring in the lower a arm,it's a 2-1 ratio,1/2 spacers will raise 1". Summit has them
Old 02-07-2016, 05:17 PM
my69camaro's Avatar
thank you. does the lower control arm have a seat these aluminum spacers sit in, and if so, will the coil spring stay sitting on these??
thanks for your help!! (GO DENVER!!)
Old 02-07-2016, 05:41 PM
80sz's Avatar
Yes,the spring will sit in a small pocket ,the spacer fits this pocket and coil will seat into spacer. Tape them to bottom of coil if stubborn to get to seat correctly,stock coils you will have a lot of turns,performance coils will be larger diameter with less turns
Old 02-07-2016, 05:47 PM
80sz's Avatar
A easy way would be just jack the subframe from the body some more,put some bigger spacers in. Lot easier then messing with coils
Old 02-08-2016, 09:08 AM
my69camaro's Avatar
thanks again for your help. I'm getting the aluminum spacers today. this is just another winter project. stay warm.
stealthy95z
06-27-2012 04:29 PM
kpmelvin19
08-05-2011 05:42 PM
T&GCAMARO
04-14-2010 07:43 PM
buckmaster
11-24-2007 11:46 PM
toolbox
03-16-2006 10:52 PM
Quick Reply: 2nd generation coil spring spacer
