1970 build....
Old 11-17-2014, 10:42 PM
Yep, I fought those new rubber bushings that came in my springs too! Wish they'd just leave them out, and put them in the package. I heated up the center sleeve to burn mine out, and what a stinky mess!
  #82
Old 11-18-2014, 09:37 AM
meanstrk's Avatar
Looks like most of the suspension is here now. Still need to get shocks ordered and new tie rods.
Uppers
Lowers...
  #83
Old 11-19-2014, 12:42 PM
meanstrk's Avatar
I have been waiting for this kit for a month!!!
  #84
Old 11-20-2014, 07:40 PM
meanstrk's Avatar
Ahh. Some go fast goodies and some whoa goodies....
Thunder stick and roller lifters....
Wilwood front brake kit. 4 piston calipers.
  #85
Old 11-20-2014, 08:05 PM
Lots of high class parts! Very nice!
  #86
Old 11-21-2014, 12:24 PM
Sudstoy's Avatar
Thats a nice front brake assembly, I installed the same one on my 70. The instructions on spindle modification is perfect too.
  #87
Old 11-23-2014, 12:07 PM
meanstrk's Avatar
Got the rear diff cover painted and installed using new 12 point ARP bolts. Guess I can set the rear end aside now...
  #88
Old 11-23-2014, 05:18 PM
You may have thought if this already, but I put paper tags on all my parts that use grease or oil, and write a note to remind me if they are full or empty. Had a bad experience once where I was away from a build for months, and forgot to add gear oil to the rear axle before the first test drive!
  #89
Old 12-01-2014, 08:24 PM
meanstrk's Avatar
Been busy on a customer project, but I finally got my rear brakes fitting up this evening. The Chevy 10/12 bolt rear ends use the same kits, which uses a 2.75" offset, but it turns out that, for some reason, one side of my axle had a 2 7/8" offset, which meant that the caliper was VERY close to the rotor. I ended up making a spacer to get the mount set up correctly to get everything centered up. Unfortunately, the kit was missing a wheel stud, so I need to call and ***** about that so I can get everything complete finally.
  #90
Old 12-02-2014, 08:56 AM
I sure like the looks of the brake setup! Too bad they can't stay so pretty, and still be driven!
Quick Reply: 1970 build....
