78-81 instrument set
Old 06-26-2014, 04:57 PM
BLK79's Avatar
Default 78-81 instrument set
I have a chance on picking up a factory gauge set for my 79 Camaro. The ad just says 78-81, it has speedo,tach, clock,fuel,water temp and volts. Can I make this work on my car that has idiot lights?
Does it have to come from the exact year of car as mine to work?
Old 11-12-2014, 12:51 AM
greencamaro1981's Avatar
are you still loking or what did you discover?
Old 11-12-2014, 04:33 AM
BLK79's Avatar
Yes I'm still looking, after seeing it in person the gauge set was garbage.
Old 11-21-2014, 03:01 AM
i installed a complete aftermarket set in my car i had the dummy lights and no tach i really like how it is set up now but i am still considering changing minor details around for the fascia
Old 03-29-2015, 04:12 PM
Rottieiller's Avatar
I just ordered a set on e-bay they seem to go for 150-300 bucks. I think the older ones will fit but the signal lights will not be the same.
Old 03-30-2015, 11:51 PM
im considering selling my stock guage cluster and the plastic bezel piece but imlazy and dragging my feet for no real reason
Old 05-17-2015, 09:58 PM
jshatek's Avatar
I think you can switch over to a guage oriented cluster, but you'll have to add some things under the hood such as a oil pressure sending switch and a temperature sending thermostat? plug, and a tach wiring harness. Hope this helps.
waffles
09-11-2009 07:52 PM
Lithorian
02-08-2009 11:57 PM
ryan88z
12-30-2007 01:34 PM
Quick Reply: 78-81 instrument set
