steering column connector plug / Ignition circuit question
Old 08-02-2015, 01:46 PM
stox58's Avatar
Default steering column connector plug / Ignition circuit question
Hi,
I'm wanting to install a hidden switch to cut the Ignition circuit, the switch is 10amp so i'm guessing that I can just use the switch connected to the ground wire.
Please can someone tell me if this would work and which colour wire I need to wire to my switch.
thanks from Luke ( 77 Camaro )
Old 08-03-2015, 05:49 AM
greencamaro1981's Avatar
ok there are 2 common hidden switches
1. power to coil wire this will make the car not run at all, will crank but no start this switch will be wired in series with the power wire to coil
2. starter exciter switch, this is wired into the exciter switch (usually a purple wire to starter or yellow on the column there are variations though) will only make it so the car will not crank i have this type in my car and i wired it so when i disengage the starter i engage the horn, so if i fail to flip switch before cranking the horns will go off
after that hiding the switch and different designs are up to you just make sure to match wire size going to a smaller wire in the starting circuit is asking for a fire
Old 08-03-2015, 12:18 PM
stox58's Avatar
Thanks for the reply
is the 10amp switch ok to use on the purple wire?. It won't be switched when the wire is live, but will still have quite a bit of current going through it when starting the car.
I thought it would be best to switch the ground wire, as your not got all the current going through it
Old 08-11-2015, 09:44 AM
I usually break the wire going to the solenoid terminal marked "S". I also break the wire going to the coil. So I use a 2 pole switch that both wires can go through to stop the engine from starting, or cranking. A 10a switch will handle both wires easily.
Old 08-13-2015, 03:54 PM
stox58's Avatar
The wire that I have is slightly smaller diameter than the original, but is rated at 17amps. I'm guessing that this will be ok?
Thanks from Luke
Old 08-13-2015, 08:54 PM
GaryDoug's Avatar
Same current goes through the ground wire. That's why it's called a circuit.
Old 09-27-2015, 03:34 AM
stox58's Avatar
Smile
Thanks for all your help, I've now sorted it and my hidden switch is working great!. I used the purple / white wire from the colume, so there is no crank until you flick the switch on.
Cheers from Luke
Old 02-29-2016, 08:16 PM
spedaleden's Avatar
I would place a relay on the starter wire to break the circuit. Use your switch to energize relay
Get a good quality relay
Cut purple or yellow wire at steering column
Terminal 87A and 85 goes to starter wire from column
Terminal 30 goes to Stater wire towards starter
Terminal 86 goes to ground, Take one lead from switch and connect to terminal 86. Take other lead from switch and go to ground.
When you flip switch nothing will happen and no drain on battery. When someone tries to steal car and ignition switch is turned to start position, relay is energized and starter wire connection is opened so car will not start.
Once ignition switch is released no drain on battery.
stox58
10-25-2011 01:53 AM
rba415
12-19-2009 07:08 PM
Greg
01-02-2009 05:01 PM
ccdalamp
05-22-2006 01:18 AM
ccdalamp
05-19-2006 04:03 PM
Quick Reply: steering column connector plug / Ignition circuit question
