rear end id
Old 12-10-2011, 01:20 PM
Dcapper81's Avatar
Default rear end id
hello everyone. ive been trying to id my rearend and i am stumped. im not even sure its original to the car or not. its a 70 camaro. the axle code is coc 0528g2. the casing code is 3969340 NF. i dont really care about the date but i just really want to know if its a camaro or a nova rearend. i also really want to know if its an 8.5 or an 8.2. It looked original because it had atleast a 1/4 inch of mud encasing it, but i dont know. it also says gm 69 on it if that helps. and the cover is smooth with an offset bump. no upside down v
thanks for your help
Old 12-10-2011, 03:18 PM
If it looks like mine, and has the little cast squared corners at the 4 o'clock and 8 o'clock positions like mine, then it's probably an original 2nd gen 8.5" rearend.
Old 12-10-2011, 08:50 PM
Dcapper81's Avatar
Thank you. It does look a lot like yours but im still not completely convinced. The 8.5 came out in 71 but my rearend looks like its never been touched. But yet it looks more like an 8.5. I found out that it had 2.73 gears in it through the number, but it doesn't tell me the size.
Old 12-10-2011, 09:00 PM
BasicConcepts's Avatar
Technical User
what size are your tires... just currious
Old 12-10-2011, 09:17 PM
77 kencraft's Avatar
Maybe this add on nasty Z28 will help Chevy Camaro Rear Axle Information & Restoration It looks like a 10 bolt 8.5" corporate rear end I just changed mine, appears we both need to get the brake line mounted down
Old 12-11-2011, 08:12 AM
Mickey Thompson N50's. They meaure about 12.5" tread. Not available any more. Bought the last pair a couple years ago.
Saaampson74
10-20-2008 04:56 PM
libertyforall1776
11-10-2007 03:04 PM
Quick Reply: rear end id
