rear end gear ratios
can you tell me all the possible rear end gear ratios for a stock 80 camaro rs? it does not have posi. to change the ratio can i buy the gears i want and replace them into my stockrear end? thanks
RE: rear end gear ratios
Try this...
You can't just "plop" gears into the rear end though as some of the parts need to be installed with a press.
I completely agree. I rebuilt the rear end in my 70 a while back, and although it ended up working out in the end, there were alot of problems. Id suggest finding a reputable shop, buying the parts, and having them press the pinionw/the crush sleeve, etc. The backlash is a critical measurement that just cant be done in the driveway...
Since the topic is gears...whats the spline for 2nd gen? I only ask because according to NastyZ28 the "corporate" rear end (1971-81 8.5' 10 bolt) is 28 spline but there's some gears out there like Richmond and other gears on Ebay that say its 30 spline for a 10 bolt 8.5'?...soooooo who's right?
