Need power for switch during ignition. Help
I am currently working on my 79 camaro installing a momentary switch and relay in line with the starter. My problem is during the starter phase the power the switch connects to cuts out. Is there a source that won't cut out during the ignition phase?
To give insight, I am doing this as a sort of anti theft deterrence.
Thanks for your time and suggestions!
Let's see,
Red wire in power from battery
Purple wire to starter solenoid in START
Pink IGN 1 to coil
Brown ACC power in IGN and ACC
Orange IGN 3 power for fuse circuits - those accessories needing IGN power command, i.e., aftermarket radio, etc.
Hope this helps.
Pink IGN 1 to coil
Hope this helps.
this is a hidden switch so you can have a hidden kill switch so its harder to steal in that case i would tap into the primary feed for the blinkers behind the fuse block
pull apart the fuse block its a good sized wire this is where you get constant key in on and crank but not in the off position
how you gonna hold a key and a monetary button at the same time? also i just have a on off switch in mine
I would place a relay on the starter wire to break the circuit. Use your switch to energize relay
Get a good quality relay
Cut purple or yellow wire at steering column
Terminal 87A and 85 goes to starter wire from column
Terminal 30 goes to Stater wire towards starter
Terminal 86 goes to ground, Take one lead from switch and connect to terminal 86. Take other lead from switch and go to ground.
When you flip switch nothing will happen and no drain on battery. When someone tries to steal car and ignition switch is turned to start position, relay is energized and starter wire connection is opened so car will not start.
Once ignition switch is released no drain on battery.
