Need Info On 1980 Camaro Berlinetta T-Top
Old 12-06-2010, 12:41 AM
kal's Avatar
kal
kal is offline
Default Need Info On 1980 Camaro Berlinetta T-Top
I have a 80 Camaro Berlinetta T-Top VIN # 1S87HAN542103. I was wanting to know if anybody can tell me something bout the Berlinetta version of the Camaro an tell me something bout the one I have?
Old 12-06-2010, 03:33 AM
80ZJoe's Avatar
July 2010 ROTM
Vehicle Identification Example: 1P87LAN547484
-First digit is GM Division: 1 = Chevrolet
-Second digit is model: P = Sport, Rally Sport, Z28, S = Berlinetta
-Digits 3 & 4 are body type: 87 = 2dr. coupe
-Fifth digit is engine code: A = 231ci V6, H = 305ci V8, J = 267ci V8, K = 229ci V6, L = 350ci V8.
-Sixth digit is model year: A = 1980
-Seventh digit is N for Norwood assembly, L for Van Nuys.
-Last six digits increased one with each car built at each plant.
1980 Berlinetta - Included Custom Interior, bright upper and lower grille, bright windshield and rear window moldings, dual pin stripe treatment, body color sport mirrors (D35), argent applique on rear panel, specific trim and either wire wheel covers (standard) or color-keyed aluminum wheels (N90, 14 x 7") (optional). Amberlite insulation blankets included in doors, rear quarters, roof/sail panels, behind rear seat, under package tray and under carpeting (RPO Z54 interior decor/quiet sound). Option U05 dual horns and U14 Special Instrumentation were also standard equipment.
If you want more info, this is were i got that stuff http://www.nastyz28.com/camaro/camaro80.php
Joe
Old 12-06-2010, 04:42 AM
kal's Avatar
kal
kal is offline
I am looking at doing a Z hood & fenders an looking into adding Z & Ralley options to the Berlinetta what would be some good options to add to it? Another thing I am going to use this for a daily driver. The car came with a auto trans but now when I got it back there is no trans in it. Would a 4 speed manual trans from a Z be better for MPG? An I was told I should go with a 305 with 350 heads for better MPG over a 350 engine. Would the 305 with 350 heads an a 4 speed manual be good on gas? I heard I might get 18-20 with that combo is this true? I am currently driving a 09 Saturn Aura XR that gets 18-20 MPG.
Old 12-06-2010, 08:46 AM
It doesn't matter which of those trannies you have. There all 1:1 in the end. No way in hell your gonna knock down 18 mpg. The bone stock one in HotRod last mont got 11.
Old 12-06-2010, 09:42 AM
I'd keep it an auto and go with a 700 or 200 for better highway mileage. That's the only way you'll increase mileage with a tranny.
Old 12-07-2010, 05:54 AM
kal's Avatar
kal
kal is offline
ok so what would I need to do to increase the MPG on this car? I am not looking for a high horse car just a fun one & cheap to drive. This is the only reason I went with it cheap to get it on the road an cheaper on gas than the truck. An on the 700 & 200 trans were can you get them at an which one between the two would be the best to go with?
Old 12-07-2010, 09:20 AM
Lots of ways to get better mileage, but not really cheap ways. Question is what are you willing to spend, and when will the return make that expenditure start saving you money at the pump?
A 700R4 would be my choice, and they are available everywhere. Start checking your local Craigslist.(I see them around here all the time) Every tranny shop sells them, or buy one new from several online sellers. Or maybe your local wrecking yard if they'll guarantee it.
Local builders sell them for around $650 rebuilt, but I see them listed as "good used" for $200-$300 often.
Old 12-08-2010, 07:51 PM
kal's Avatar
kal
kal is offline
I am looking at going 4 speed manual with 305 high output an see how that does. I just want something easier on gas than my 74 F250 crew with 390 & 4 speed manual with granny gear.
JD79Camaro
12-01-2009 07:03 PM
athleticboy17
09-01-2009 10:36 PM
trj
06-23-2009 08:40 PM
hellraiser5010
82-92 V8 Tech
08-15-2008 06:45 AM
ricozero
05-07-2007 12:05 AM
Quick Reply: Need Info On 1980 Camaro Berlinetta T-Top
