How do you take out the back seats of 1976?
Once you push the seat bottoms back hard, then pull up. The backrest has two bolts at the bottom that are revealed after the seat bottom cushion is pulled. Pull those, then lift straight up to get it off the hooks.
Same as the front. You'll need to slide the seats forward or back to get at all 4 bolts. Don't forget some penetrant on the bottom side of the bolts! They hang through the floors, so they often get pretty rusty below.
