Engine Compartment Paint
Im thinking about painting my engine compartment. I know I want semi-gloss black, but Im not sure what kind of paint to use. Should I use engine paint or is regular rustoleum good enough, or should I use something else? thanks
RE: Engine Compartment Paint
We use SEM Rust Shield part# 38101. It is a satin finish black that is very close to factory finish. It can be applied directly to bare steel or over a primer. You can spray the paint just as it is from the can but we reduce it 10% for better flow. Three good wet coats on bare metal gives excellent rust protection over sandblasted frames and under-bodies.
