79 Camaro Turns over KOEO
Old 07-27-2014, 09:13 PM
Branley's Avatar
Default 79 Camaro Turns over KOEO
I have a 1979 Camaro I just received and it used to be a 350 car but is swapped to a 305 and it turns over and tries to start when I turn the key on not trying to start it. Any ideas?
Old 07-28-2014, 07:58 AM
Yes. Look at the small starter wires hooked to the solenoid. Should be one on each terminal, and they're probably either swapped wrong, or two are both on the same side. One hooks to the alternator, so it's feeding back when you turn the key on. Swap to the other terminal and it should work.
laredocamaro
07-26-2011 07:33 PM
Jerry95lt1
03-29-2011 12:24 PM
Jerry95lt1
10-28-2010 01:38 AM
jramirez911
07-19-2010 02:20 PM
NEW_CAMARO_OWNER
04-28-2010 06:34 PM
Quick Reply: 79 Camaro Turns over KOEO
