79 camaro acceleration problems
Old 10-08-2009, 01:16 PM
wade79camaro's Avatar
Default 79 camaro acceleration problems
79 350 we have changed the fuel filter ,fuel pump, cap and rotor car will not go when you give it the gas it falls on its face, could it be bad ignition module????? or possible clogged CAT
Old 10-08-2009, 01:32 PM
matts79's Avatar
I had the same problem. Took a new distributor but you could try the module first
Old 10-09-2009, 07:48 AM
I may be to that point, also when I put the new cap and rotor in my tach quit working, the only thing I have left to change is the coil the distriutor and te ballast resistor????????
Old 10-09-2009, 10:09 AM
What ballast resistor?
You running HEI ignition? If so, your tach problem is a broken, mixed up, or forgotten wire. One of the wires to the dist cap is for the tach.
And have you checked your timing?
Old 10-09-2009, 10:17 AM
I have not put a timing light on it yet, but the problem happened while he was driving the car wich makes me think there is a component failure?
Old 10-09-2009, 11:06 AM
You running a stock GM HEI distributor?
Old 10-11-2009, 01:39 PM
I get it! no ballast resistor, the problem is solved we ahd a bad gasket between the carb and intake and needed the carb cleaned.
Hazard29
04-15-2011 11:17 AM
Hazard29
01-30-2011 03:15 PM
vladaro
08-29-2010 01:44 AM
Baseballchris05
05-06-2007 01:46 AM
Lush
05-14-2006 10:39 PM
Quick Reply: 79 camaro acceleration problems
