tire size for 17x8 wheels
Old 08-17-2014, 08:11 AM
southw2's Avatar
Default tire size for 17x8 wheels
I would like to know which is the largest size tire i can put on the back of my 68 camaro. I have 17x7 4" bs rims in front with 235-45-17 bridgestone potenzas on the front.
The rear wheels are 17x8 4.5 backspacing.
Any suggestions would be appreciated.
Thanks
Ted
Old 08-17-2014, 08:42 AM
i would not go bigger than 245's check out the tire rack site. they give you the industry standard for tire fit. you can go as wide as a tire will fit. tire performance goes south once you get by a certain width for a rim though
Old 10-08-2014, 04:13 PM
DeereMan's Avatar
Have you seen the 48 Hour Camaro build? They are running 18x10 275s front and 18x12 335s rear with bolt on parts and mini-tubs. Check out the following link, it might give you some idea of what is possible these days.
48 Hour Camaro
Old 01-22-2015, 02:09 PM
Nova117's Avatar
Thanks
Ted
I just installed Nitto 255 45 17 on the Rear of a 69 Camaro 17 x 8 4.5" BS REV 107 Wheels
235 45 17 on the front 17 x 7 4" BS
No Issues
Old 03-08-2015, 03:38 AM
Default Best Fitting Tires for 17x8 Wheel?
Greetings, I have a 2001 Acura CL Type-S. The stock rim and tire fitment is 17x7 with 215/50-17 tires. I recently purchased a set of 17x8 wheels. will the 215/50-17 fit the new wheels ? and if not what would be a better fitting tire ?
Old 03-10-2015, 02:53 PM
ShadowLP's Avatar
Old 03-27-2015, 03:23 PM
Billdoe69's Avatar
Thanks
Ted
I have a 69 Camaro and have researched what will fit the 69. not sure if 67-68 are different but.. I was told with a 17x8 wheel in front with 4 3/4 BS you can fit a 245-45-17 and on the rear with a 17x9.5 wheel with 5.5 to 5 3/4 BS can fit a 275-40-17.. again this is a 69 Camaro and I believe they have slightly larger quarter panel and fender gaps for larger tires.. best to call a tire shop that can get in touch with someone that knows for sure.. that's what I did..
Old 04-25-2015, 03:53 PM
Mark L's Avatar
Can I ask where you found that, because I am wanting to go with 18s and just curious if anything changes when you go from 17 to 18?
Old 10-18-2016, 01:47 PM
Tlhernan's Avatar
I just put on 17"x9" with 5" backspacing 275/40r17 BF Goodrich Sport Comp 2s on the rear.
And a 17"x8" with 4.5" backspacing 245/40r17 BF Goodrich Sport Comp 2s on the front.
I have a 67 Camaro with a BRP Hotrod rear shock relocator. Its fits right on the inside of the fender.
Old 10-23-2019, 08:40 AM
majj35's Avatar
No Issues
I know this is old. .. but im looking for photos for that EXACT setup! please send me photos if you can
Quick Reply: tire size for 17x8 wheels
