Sheet metal parts related to headlight 67 Camaro
Wheres a good place to find out what are all the body related parts needed for installing headlights? I picked up a rolling shell of a 67 Camaro which is pretty stripped down. I have some of the parts but I'm trying to figure out what all I'll need. The shell has the front fenders, hood, radiator support, steering & suspension for the front part of the car. I have a service manual but it doesnt list all the parts. Thanks in advance for any support anyone can offer.
Thanks
Hawkfan
Tinley Park, ILL.
Thanks
Hawkfan
Tinley Park, ILL.
You need the following inner fender right and left, add RS if you want RS.. Fenders right and left add RS etc.. You need radiator support, headlight buckets, headlight mounting brackets and all the screws and bolts..
Best place to see what all you need is to get a catalog from Classic Industries. I've been working through one recently, and was amazed at the detailed exploded diagrams inside that show all the parts in their order. Makes it so much easier to figure out exactly what you need, and how it goes together.
Be sure you've got standard outer fenders, before you decide to go with a standard grille, and headlights. If it doesn't have the tabs and pieces in the headlight opening of the fenders, it wont accept standard grille and headlight assemblies.
ToddB
07-31-2010 12:53 PM
