..Front Wheel Diameter Different Size Than Rear? - Page 2 - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 03-20-2017, 05:22 PM
Everett#2390's Avatar
As one can imagine, once the 'stance' is set, front end alignment is needed.
Picture, if you will, sitting to the side of a front wheel, X amount of caster is shimmed in, say 1/2 neg - Camaro sitting level.
Now, raise rear of Camaro, caster is lost, changed towards positive.
Steering now wonders at high seed.
Caster needs to go back into alignment, and Camaro can be shimmed for as much as 3 neg.
Toe must be reset also as now as contact patch is in a different place on the tire.
Regardless of tire/wheel size/stance is chosen, a four-wheel alignment by a good alignment tech is needed. Not just one who reads the book and sets it by the book, needs to be set by real world usage.
Reply
Thread Thread Starter Forum Replies Last Post
3.8 Stock Exhaust diameter Chevyfan99 93-02 V6 Tech 4 06-26-2013 04:41 PM
Is the bcm different in a 1997 than a 2000? siueparent 93-02 General 6 10-06-2009 03:49 PM
exhaust cutout, what diameter? 94 z28 93-02 General 5 03-10-2008 05:11 PM
different wheel color 350rs 82-92 General 3 08-13-2007 12:01 PM
Stock Downpipe diameter size SmokEater 93-02 General 2 07-03-2006 07:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
