69 Voltage regulator wiring - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 11-09-2007, 08:11 PM
Default 69 Voltage regulator wiring
New to boards and did a search but came up with nothing. I just got this Camaro running and am tring to fix all the bugs left in it by previous owner. It was not charging and I had to replace alt and regulator. Gen light would stay on with key off some times so I figured a bad diode. Voltage regulator was burnt and after market gauge was reading low. So after replacing both parts it was then running and charging. Only problem is now it wont shut off. I un plugged HEI at "batt" and it quits. Peeled back harness to distributer and find a mess of wires and appears that it is all hooked together and going to the voltage regulator. So i disconnect all the wires going to the distributer except the black one and it starts and runsand shuts off. Now I have no power to the #4 terminal of the VR and it wont charge. It look like there is supposed to be a brown wire that feed this terminal but I have a red one. Does any one have a good diagram og thei system?
Old 11-11-2007, 11:47 AM
Default RE: 69 Voltage regulator wiring
I have a good 1969 chassis service manual that shows different diagrams as well as diagnostic info for the charging system (8 pages). If you have access to a fax machine, I can send you copies.
Old 11-16-2007, 11:57 AM
Thanks, I PMed you my fax number
Old 11-17-2007, 05:49 PM
You've been faxed! Did that info answer your question?
Old 11-17-2007, 09:17 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Camaro 69, can you make those digital so we can post them up here?
Reply
Thread Thread Starter Forum Replies Last Post
Voltage Regulator Noise palmers68 67-69 General 2 04-08-2013 09:01 PM
Voltage Regulator diode? / Wire harness StoveBolts 67-69 General 40 02-03-2011 10:24 AM
Proper Voltage Regulator Mounting 1969_RS 67-69 General 0 07-30-2010 08:08 PM
Alternator/ voltage regulator problem? 87mgte 93-02 V6 Tech 1 12-14-2008 07:07 PM
VOLTAGE REGULATOR camaro70 70-81 General 2 01-16-2008 09:12 PM
Tags
1969, 350, 69, c10, camaro, chevrolet, chevy, diagram, gen, light, regulator, v8, voltage, wiers, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
