68 starts but needs gas
PCV to power brake port... The port on the carb, or on the booster? Is it T'd to connect both the brake booster and PCV into the carb base?
Unless someone modified your distributor to run on full manifold vacuum, your advance isn't working right. Try moving vac advance to the ported/timed fitting. Trans modulator wants full manifold vacuum.
Ported vs full manifold distributor advance is a discussion all it's own.
I'm talking about the port on the carb.
96CamaroLT-1
12-11-2011 06:42 AM
