Powerglide Slipping in Park
Just picked up a new problem with my 67 Camaro with a 327 and Powerglide. When I place the shifter in park on a slight incline, the car rolls about a foot and makes several clicking sounds before coming to a stop. Otherwise the trans works fine when the car is running. Hopefully just needs a little adjustment. Any suggestions?
Check to make sure your shifter/linkage is putting it all the way into the park position. Once in park, block the wheels and disconnect the cable at the trans bracket. See if the transmission shift lever has any further movement beyond where the cable put it.
