67 lower speedometer cable replacement
I am trying to replace my lower speedometer cable on my 67 Camaro. The 3 speed manual transmission has a two part cable. The lower cable has broken and needs to be replaced.
The cable is routed between the frame assemble for the front end and the body. There is no room to pull the cable ends between the frame and the uni body.
Does anyone know the procedure to replace the lower speedometer cable?
Thanks.
Thanks.
