350 turbo to 400 turbo mods if any?
Old 01-19-2017, 04:52 PM
bigwave1971's Avatar
Default 350 turbo to 400 turbo mods if any?
I'm putting a 400 turbo in my 67 and I have a 350 engine, is the any modifications I need to know about? will everything bolt up with no problems? what do I need to do? Thanks in advance
Old 01-20-2017, 01:00 PM
Everett#2390's Avatar
Depends upon what options the Camaro was born with.
If a true SS, BBC/SBC with automatic, then already there.
If base model, she came equipped with PG/3-spd/4-spd, then the trans crossmember will have to be changed for a THM400 unit and a shorter driveshaft.
Also, kickdown switch on carb throttle linkage.
Detent plate of shifter will have to be modified for access to 1st gear manually.
Longer trans oil cooler lines.
Old 01-21-2017, 06:45 AM
its a true rs and had a 350 with a powerglide
Old 01-21-2017, 06:15 PM
Here's the RPO M40 from the 1967 AIM:
Gives an idea of parts needed.
File Type: pdf
Old 01-21-2017, 06:17 PM
RS Pkg is an appearance option, could be gotten with a L6/3-spd manual.
Old 01-22-2017, 06:30 PM
looks good thanks
johngindrup
10-21-2014 07:44 AM
BM-Z28KING12
05-26-2012 01:44 AM
Sixty7 Camaro
04-11-2009 12:54 PM
mycarsux88
12-11-2007 10:44 PM
Quick Reply: 350 turbo to 400 turbo mods if any?
