1967 Transmission Issues
Old 01-08-2017, 09:46 PM
Ajramos05's Avatar
Default 1967 Transmission Issues
Folks, I appreciate all the assistance I received related my backup lights and oil pressure issues. All is working well in those areas. Now I have a different issue. Lately my transmission appears to be slipping or slagging as I accelerate. I googled the symptom and everything I found states that the TH 350 doesn't have belts, what can be the issue?
Jerry
Old 01-09-2017, 05:56 AM
flat tire's Avatar
clutch pack
Old 01-09-2017, 09:15 AM
Everett#2390's Avatar
As suggested, clutches need exchanging (trans overhaul) or low fluid level.
Old 01-09-2017, 09:47 AM
Ajramos05's Avatar
Do automatic transmissions have a clutch?
Old 01-09-2017, 10:19 AM
flat tire's Avatar
Old 01-09-2017, 01:14 PM
Yes, they do, one set for each gear.
As an auto trans upshifts, forced oil is channeled into the planetary gear hub pressing on a piston to 'clamp' clutches together making the unit turn as one.
When clutches disengaged, planetary gear turns as this gives a gear ratio, 1st, 2nd, 3rd gear.
Clamp via pressurized oil, a gearset becomes one, upshift to next gear has happened.
I had a friend's THM350 due for overhaul. The clutches were burnt so bad, they became one unit, so when trans upshifted to second gear, the vehicle came to a skidding stop.
67camRSSS
67-69 V8 Tech
20
03-24-2015 08:53 PM
minex
09-08-2010 01:27 PM
ctc1111
04-17-2008 02:44 PM
bullrunbattle
02-13-2007 02:47 AM
crippleddave
07-08-2006 02:01 AM
Quick Reply: 1967 Transmission Issues
