pics of 68 after new suspension installed
#21
I will get you the tire size soon. Front wheel off set I believe is 4 inch. Replacing my suspension fixed my bad lean I had on passenger side do to the sagging rear Springs. The new body bushings helped also. I still have a rub on front and rear passenger side now after drop when hitting bumps and steeper drives. I keep wondering if I put battery in trunk if it would help front some. With a passenger it is worse. I have a set of front spring spacers and rear shackles sitting in garage that I bought if lowering caused a problem. I am considering installing to gain a half to an inch lift back up. The rubbing was not so bad at first but over the last year after installation it has settled.
I could probably go with a smaller tire size but that will be. While as these are all new tires on it still.
