pics of 68 after new suspension installed
Old 10-19-2014, 08:40 AM
thefley's Avatar
December 2012 Ride of the Month
I will get you the tire size soon. Front wheel off set I believe is 4 inch. Replacing my suspension fixed my bad lean I had on passenger side do to the sagging rear Springs. The new body bushings helped also. I still have a rub on front and rear passenger side now after drop when hitting bumps and steeper drives. I keep wondering if I put battery in trunk if it would help front some. With a passenger it is worse. I have a set of front spring spacers and rear shackles sitting in garage that I bought if lowering caused a problem. I am considering installing to gain a half to an inch lift back up. The rubbing was not so bad at first but over the last year after installation it has settled.
I could probably go with a smaller tire size but that will be. While as these are all new tires on it still.
  #22
Old 11-25-2016, 10:22 AM
MikeJ67's Avatar
Wow, looks great. So what was the final drop front & rear? I'm in the process now of gathering parts (almost done) to do a suspension/brake upgrade on my 67 sooooooon.
|m()d
01-23-2013 04:16 PM
2Z's
09-05-2012 07:02 PM
Chevy101
03-31-2010 04:53 AM
BadBowTie93
06-03-2009 08:15 AM
1994z28
09-29-2007 05:39 PM
Quick Reply: pics of 68 after new suspension installed
