Need some guidance on front springs....
Old 03-29-2015, 12:54 AM
67camRSSS's Avatar
My car is factory A/C, with that being said they used a B/B spring even though it's a small block for the additional weight. I think it was overkill but oh well. I ended up cutting off 1 coil and it sits perfect for me, but I'm not running headers either. I haven't noticed it settling. Now the back is a completely different story, it settled way to much and now I can't put passengers in the back without getting tire rub on a bump. Any ideas? I thought about air shocks, they were new springs when I installed them. I'm just afraid the shock mounts in the back aren't strudy enough for air ride.
Old 04-01-2015, 05:46 AM
kuhlman187's Avatar
idk if my mounts have been modified to be honest, but the car sits lower on passenger side by 1.5" I found this out after installing 3" drop hotchkis multi-leaf's. put the previous multi-leaf back in and it sits level... the car with no air in the shocks is LOW.. about 1" over the rear tire. I lift it a couple inches with the air shocks and it seems to be fine.
Old 12-03-2016, 12:44 PM
MikeJ67's Avatar
That's one sweet looking ride. I cut a set of springs on a 65 chevy I built. I went a full 1.5 coils. (I should have gone just 1) the car sat real nice and rode great. Then I put some 17s on it and I was about 1/2" too low. Since the wheels/tires were new, I tried to roll the fender lips, but they were too strong. So I just cut the inner lip off the car. It was just about 1/4" away from being perfect, but I didn't want to buy new springs to try it again. I had a lot of fun in that car. Sure wish I could figure out how to add pics here. Hmmmm
Old 08-04-2017, 07:21 AM
68hou's Avatar
More costly, but with double adjustable coilovers, you can dial-in the ride height within reason and the shocks are fully adjustable for compression and rebound. I dropped my 68 about 2" in the front. Have you installed tubular A - Frames?
Old 08-21-2017, 12:01 PM
kuhlman187's Avatar
I haven't added tubular A-arms yet. I got the ride height dial in to an extent but i'm still interested in double adjustable coilovers. curious how difficult tubular a-arms are to install.
Old 08-28-2017, 07:51 PM
MikeJ67's Avatar
I've got tubular upper & lower control arms going on and my CPP big brake kit came with 2" lowered spindles. I opted to get Bell Teck 1" lowered springs for a 3" total amount. BUT after putting new poly body bushings on the car, it raised it 1" due to the old worn out ones on the car. So in my case, it will probably be 1.5" - 2" tops due to the old springs having sag in them too. I also went with KYB Gas-a-just shocks because I like it a little stiff --- and that also raised the car a bit.
Good luck on your ride. Since these things are 50 years old now, they are all a little bit different.
Post some pics - that is one sweet vert.
Old 03-05-2018, 10:03 AM
Al Loyrat's Avatar
Yes, give some driving time in settling the springs.
If you do decide to cut coils later, do a half a coil at a time.
ripigs
07-04-2013 08:13 AM
libertyforall1776
09-09-2012 11:55 PM
playboy
07-07-2010 03:24 PM
srich1207
07-08-2008 12:50 PM
1stgenssclone
11-27-2007 06:26 AM
Quick Reply: Need some guidance on front springs....
