67 Camaro guard rubbing
Old 06-29-2015, 03:48 AM
camaro396's Avatar
Default 67 Camaro guard rubbing
Hi guys
I have a 67 Camaro and when I go over a bump or dip in the road it rubs on the left hand guard. Could this be a defective shocker?
Old 06-29-2015, 06:41 AM
camaro396's Avatar
after inspecting the suspension more closely I found this nut installed in the middle of the coil spring. Has anyone ever seen this before? Is this an attempt to stiffen the suspension up?
Old 06-29-2015, 08:40 AM
That's a coil spring jack/expander, not really good for the spring. To install, you put it between the coils and turn. Yes, it's an attempt to stiffen the coil, to compensate for worn out sagging springs.
Given that you're getting rubbing (what is the "it" that rubs btw), nice new springs are in your future.
Old 06-30-2015, 07:54 AM
camaro396's Avatar
I meant the tyre rubs on the guard
Old 06-30-2015, 08:49 AM
camaro396's Avatar
so if I was to take out this jack/expander would it make the problem worse?
Old 06-30-2015, 10:39 AM
Yes, the front will sag more in front without it.
markinnaples
10
06-07-2015 09:06 PM
the_donace
08-07-2012 02:16 AM
RFxCamaro
11-06-2010 08:47 PM
the_donace
06-30-2010 01:43 PM
Quick Reply: 67 Camaro guard rubbing
