09-03-2011, 10:14 AM
Lot of work ahead of you, but the first time you start 'her' up, it'll all be worth it.
09-13-2011, 01:08 PM
Reply to StoveBolts
It is a big space to heat, we plan on using wood  . I live just south of St. Louis, MO and it does get cold here in the wintertime. We know how to bundle up though so I'm sure the hubby and I will have fun even in the freezing cold, hehehe. The heat so far hasn't been too bad. We went with a white colored roof which helps to block the heat out.
The car has doors, a front clip, and trunk deck. It was all removed in order to do a frame up resto. Hubby worked on the rockers this weekend, then we will work on the underbody and pull the front and rear out of the car and redo all of that. Then we get to start putting it all back together. We do not have a motor as of yet, but we are a little ways off from needing that. The other major component missing as far as the body is the radiator support in the front.
Does anyone know the best places to get good replacement parts that fit well? I'm looking for both the radiator support (core support) and the tail light pan (all needs replaced) for the back.
Quote:
Originally Posted by StoveBolts
Looks like you've certainly got your work cut out for ya! Not sure where you live, but are you going to need heat in there too? That's a big space to heat, especially with no insulation and metal walls. I imagine it could get pretty hot in there too.
Who cares though right LOL< you've got a fantastic space to work on your car, and it will be exciting to watch your build progress over the next year or so!
Where are the doors and the front clip and trunk deck? Did you already pull them off? What about the engine? Do you have one that your going to use, or do you need that too?
Awesome project, and it looks like fun for the whole family! Your son is going to love driving in it when it's finished!
Take lots of pictures and keep us posted!
__________________
Her name is Baby Girl because I found her in the corner, and nobody puts Baby in the corner.
Jennifer
09-13-2011, 01:12 PM
Reply to Formula Outlaw
Quote:
No doubt!! I can't wait for that. I've been keeping list of our progress because it helps me to see what all we accomplish each time we work on it. Seems to help pass the time.
__________________
Jennifer
09-13-2011, 01:18 PM
Reply to JG69
Quote:
Originally Posted by JG69
Smart girl buying that 69 ! Looks like a great project and one that will only go up in value. Take your time with her and have a plan. Don't get frustrated when the project takes a little longer than expected. Remember...it will all be worth it in the end. You will have a fine 69. Keep the pictures coming and good luck.
Thanks for the advice. We plan to take our time because available funds will force us do that, lol!!
Do you have any idea what the best way is to post your progess? Should I open a new thread under projects and just keep adding to it, or should I create new threads for the progress we make?
__________________
Jennifer
09-13-2011, 02:06 PM
You're already off to a good start making this a project thread, might as well just keep adding to it.
I can move this thread to the projects section, which would make more sense.
__________________
393 Stroker, Tunnel Ram, Dual Holley's
"I only live for today, but I'm one day behind"
Eats Rice and Poops Out Fords.
09-18-2011, 10:49 AM
Move My Thread
That would be great if you could just move my thread to the projects section.
Thanks a mil,
Jen
__________________
Jennifer
10-28-2011, 06:53 PM
HELP ME TOM CRUISE Yaaarrrrrr
1969 Chevrolet Camaro
Thanks for positing the pics... keep em comming.
__________________
Quote:
Originally Posted by hondurCivic
u just a dumb admin who thank he all badass becuz u own a camaro.
ur just a dumb poopoo head idiot.
HONDURS R TEH BESTEST!
Quote:
Originally Posted by cplthomas
Rainbow.... you are awesome
Quote:
Originally Posted by puck90a
Go to settings and see if there's a check next to "noob."
01-22-2012, 06:05 PM
I use a big roll of plastic and make a wall in the garage to divide up the big space and only heat the part you plastic off.
even use the plastic as a ceiling , your heat will all go up.. you can heat up a smaller area a lot better.
__________________
Jeff
" Small blocks are not Small just not as Big "
02-19-2012, 02:04 PM
An Update On Progress
We finally pulled the entire front end out of the car, took a lot of pictures (so we can put   it back together, lol), took it apart, cleaned up all the parts and started painting.
Yep, that is me (a woman) sand blasting. Tons of fun!!!
and above is me and a girlfriend taking the bumper brackets off the frame. She busted a knuckle (ouch). Those things were rusted on and hard to get off.
Ohh, and I can't forget to show you my husband's homemade stand for the front end of the car. We can actually pick it up and move it around the garage.
And then here is part of the finished product. Pretty, huh???
I decided to play with one of the fenders too!!
We are still working on putting the front end back together. The A-arms have all been blasted and painted and all new bushings and ball joints installed. We actually had to take two of the ball joints to the machine shop and have them pressed in as it took 4 tons of pressure to get them in their new resting spot.
Hubby also started working on replacing the tail pan. Does anyone have any advice on how to line up the trunk lid? We are having an issue with the drivers side back corner by the hinges sitting above the body of the car. Since the trunk lid hinges are not adjustable, what is the best fix to get the trunk lid to line up with the body properly.
Thanks for viewing and I will update again soon!!
Jennifer
__________________
Jennifer
02-19-2012, 02:53 PM
Frame is looking perty, keep up the good work!
__________________
Tags
1971, 69, baby, camaro, car, chevrolet, chevy, corner, cutaway, foundnot, girl, girls, photos, puts, ricks  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
