new door rubbers reproduction or originals
Old 01-17-2014, 03:58 AM
side-winder's Avatar
Talking new door rubbers reproduction or originals
Hallo
I have a camaro off 68.
I have new door rubbers but I don’t can close the doors, I have tried everything.
Is there a big difference withe the reproduction than the originals?
Kind regards from Belgium.
Old 01-17-2014, 07:56 AM
usually is a small difference. may have to heat a tad to soften it. maybe set the door catch lose so it will close just not all the way. then let it set closed to compress the seal, set latch a little tighter and let set. pictures?
Old 01-17-2014, 08:35 AM
By nature, brand new seals are going to be tighter than the old compressed worn out deteriorated ones were. What is your weather like right now? You want to have a real good hot sunny day, pull the car outside to bake in the sun for a while, then see if you can get the doors closed all the way, and leave it outside the rest of the day. When closing the doors, if all else fails, slam it dammit!
Old 01-17-2014, 11:23 AM
old hoon's Avatar
My car had new rubbers on it when I bought it.Over a year later I still have to slam the doors shut.
Old 02-07-2014, 11:29 AM
Mark212's Avatar
First off I am not a pro on restorations but I ordered the reproduction seals because of the price difference and I had a slight leak but only for a few days. Where I have trouble now is the trunk. I have replaced all seals including the tailights but water still gets in the trunk.
Mark G
Old 06-18-2014, 03:16 AM
i have put the doors rubbers of a camaro 67 on it and the door shut normally. there are smaller
greetz from belgium
Old 06-18-2014, 05:32 AM
flat tire's Avatar
my door seals are only 1 year old. they are repos and I never had any problem from the day they were installed
I do have to shut the door a little harder than before
Old 06-18-2014, 05:36 AM
flat tire's Avatar
Mark G
water is possibly entering the trunk from the bottom edge of your back glass
pull the back seat.. have someone in the car.. spray the back glass area with a water hose
Old 01-06-2015, 11:55 PM
Aliraza351's Avatar
Nice post
_______________________
Get ccna exam code for test king and cisco certification with 100% MB7-709 guaranteed. Our high quality fcc prepares you well before www.pittstate.edu in the final exams of Southern California University of Health Sciences.
side-winder
02-26-2013 02:32 AM
phxcosmo
12-08-2012 04:35 PM
Crutjd
05-15-2012 09:15 AM
bns454
03-16-2010 06:33 AM
jsyi
10-28-2006 02:07 PM
Quick Reply: new door rubbers reproduction or originals
