67 console gauge installation
Old 07-30-2014, 07:45 AM
camaro396's Avatar
Default 67 console gauge installation
Hi All
I am going to install console gauges to my 67 Camaro that had no console gauges and I was wondering what the process is? Can you use your original console and if so how do I know where to cut it? Also where does the wiring for the gauges plug into?
Old 08-01-2014, 05:48 AM
Everett#2390's Avatar
Dash harness needs console connector, otherwise, you'll be splicing and eliminating dash instruments.
These schematics may help.
File Type: pdf
Old 02-18-2020, 01:31 PM
mikebrow74's Avatar
You are going to need to drill 4 holes in the transmission tunnel. The forward 2 to will be used for the front "U" shaped bracket. Then there are 2 holes behind the shifter hole that you will need to drill for 5/16" nutserts. One bolt head will be in the right front of the console glove box and the other under the rear ashtray. The Factory Assembly Manual has all the dimensions. I can't recall but there may also be dimples where the holes need to be drilled. You are also going to need to convert your non-gauge harness to a gauge harness. There are conversion harnesses available.
camaro396
07-21-2015 02:43 AM
camaro396
06-15-2015 08:57 AM
camaro396
08-05-2014 06:31 AM
loyal gaurdian
11-01-2013 01:07 PM
aperjo
08-12-2009 02:48 PM
Quick Reply: 67 console gauge installation
