dummi light temp goes on!
Old 02-06-2015, 02:08 AM
gwen's Avatar
Default dummi light temp goes on!
hello,
i am from Belgium and i have a camaro 68.
i have a prob with the lamp in the dash thats indicate the temperature( dummi lamp)
when the engine is cold and i turn it on afther 5-10 min the dummi lamp go s on. the engine temp is 200-210 farenheit and it stays on that. so evrything normal. its a new radiator new water pump and a new sensor. its strange that the dummi light of the temp go s on after 10min. when i take the cable of the sensor the light goes off. when i put the cable on a negative(engine) the light goes on. is it not an electric prob?
i hope someone can help me. it turns me crasy
thanks and greetz from Belgium.
Old 02-06-2015, 09:30 AM
Icecobra's Avatar
Replace sensor
Old 02-27-2015, 09:18 AM
gbauer's Avatar
Where is the sensor located? Is it next to the exhaust manifold or on the thermostat housing neck? If on the exhaust manifold GM knew this was a problem and later moved it to the housing. That might be your issue.
I, for one, and doing away with the dummy light all together and using a 3 gauge pod with oil pressure, coolant temp and voltage.
gwen
02-16-2015 03:31 AM
kuhlman187
12-23-2014 05:56 AM
lowmileage
08-29-2008 08:01 AM
Pro_built7
82-92 V8 Tech
08-05-2007 01:43 PM
57dv
08-25-2006 01:44 AM
Quick Reply: dummi light temp goes on!
