68 camaro headers
Old 09-11-2016, 08:57 AM
southw2's Avatar
Default 68 camaro headers
Can someone steer me into which set of headers fit on a 68 camaro big block with standard trans/ power steering.
I would like some sort of coated style to help keep the heat down as much as possible.
Thanks
Ted
Old 09-16-2016, 11:27 AM
Everett#2390's Avatar
Lemons Headers are nice.
Tip: BBC with raised exhaust ports will require different headers than a stock port location port head.
Old 10-20-2016, 06:04 AM
bruce69camaro's Avatar
I currently have Hedman 68190, that is 1-3/4" tubes and 3" collectors.
I used them in both my 68 and 69 Camaro with a 396 and had no issues with clearance.
Now if you need larger tubes, because of the motor size, I have seen some headers that had the one tube by the steering box, banged up pretty bad.
Most all header companies now off some type of thermal coating, but I just use the steel headers and when needed, use a BBQ grill type paint to recoat them.
Old 12-13-2016, 03:05 PM
Brents68's Avatar
Call Summit racing and ask them...I just did that because a switched to a T5 and the shortys and long tube headmans. I have do not fit...they sold me a set of ceramic coated Patriot headers. Very nice pieces that fit perfectly. I too have power steering and power brakes. The patriots hug the block a little more and with a big block your going to need it. Oh yeah..about $370 bucks for the small block version.
2fast4u
06-04-2007 08:34 PM
Bucyrus
03-11-2007 05:06 PM
freebird230
08-17-2006 03:51 PM
chev
12-17-2005 07:32 PM
Monstermach
11-17-2005 12:48 PM
Quick Reply: 68 camaro headers
