rear main seal? - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
LinkBack Thread Tools Search this Thread
Old 09-11-2007, 09:07 PM
Default rear main seal?
Hey guys, I think I need to replace my rear seal, does anyone know if it is a 1 or 2 piece? The block # is 3970014 4 bot main from 1970. The engine was rebuilt driven about 3000 miles and sat for almost 20 years, I rebuilt the top, heads intake and carb. New push rods, rockers and got it all back together. Now I have a leak lots of oil. It seems to be dripping around the transmission shroud.
any suggestions Please. Also have oil in drivers side exhaust. When I had the heads off the cylinder walls were perfect. Help.
Old 09-12-2007, 01:51 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: rear main seal?
I cant remember exactly, but I think you can get them either 1 or 2 piece. I vaguely remember something about gm going to 1 piece to replace the 2 piece - or it was an after market sompany that offers them in 1 piece. something like that. I could be wrong.
Old 09-12-2007, 02:27 PM
On the smallblock the seal is dependant on the block design long story short its a 2 piece design in the 70s pull off cover block car slide under and look where it it leaking. You can also check the oil galley plugs in the back of the block by the cam and more unlikely the oil pressure fitting at the back top of the block. Oil in the exhaust could be?? poor ring seal check compression to the other cylinders.... Valve guides and or seals... inspect seals check guide clearance, cracks or head gasket (this is very unlikely)..
Old 09-12-2007, 09:31 PM
Thanks guys, I think I will investigate alittle further. But I think a stroker build is on its way. You know this sucks after all the hard work to now have to go a tear it up again.
Crap if I'm going to do it might has well go all the way.
Old 09-13-2007, 12:53 PM
1969 SS's Avatar
old blocks are two-piece. lots of people pinch the valve cover gaskets in the back and get leaks like you speak of and think it's their rear main seal, and after the work you just mentioned, I would think it might be a safe bet
Old 09-13-2007, 08:35 PM
1969 ss, Thanks for the tip, I will install a new set of gaskets and check it out. I have a spare set floatingaround in the garage. If it works you just saved me alot of time and work.
I will let you know.
Thanks.
Old 09-13-2007, 09:56 PM
Okay I change valve cover gaskets retimed it and took it out for a spin and looks good so far. I dont think its leaking any more but its dark out and late I will check it out tommorrow and let you know.
Wow I hope my week end plans have changed. Didnt really want to pull it yet.
Old 09-14-2007, 01:03 PM
I think that might have taken care of the big leak. Thanks, now I need to do the oil pan with a 1 piece. Should be an adventure on that one.
Old 09-14-2007, 01:53 PM
If it is a stock oil pan the front seal on the early 70s used a thinner seal if you use the thicker one the pan will not bolt down tight. What happened to the oil in the exhaust?
Old 09-14-2007, 03:32 PM
still have black spatter, dont know if its carbon or oil? When I had the heads off the cylinder walls looked brand new.
dirver side is still stronger preassure than the passenger side. Dont think that is normal.
Reply
Thread Thread Starter Forum Replies Last Post
Rear main seal Chevy101 93-02 V6 Tech 19 07-07-2012 08:02 PM
rear main seal bd92rs 70-81 General 1 12-17-2010 12:03 AM
rear main seal 94ttop 93-02 V6 Tech 6 08-13-2009 09:23 PM
Rear main seal? sp9o3 93-02 General 4 11-29-2007 08:27 PM
Rear Main Seal fix 94Red 93-02 General 5 08-29-2007 11:02 AM
Tags
1968, 1969, 3970014, 70, block, camaro, change, chevy, gm, installation, leak, main, picture, piece, rear, replace, seal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
