Quadrajet 4MV Hot Idle Compensator
Old 09-30-2014, 12:27 PM
santa6's Avatar
Default Quadrajet 4MV Hot Idle Compensator
69 Pace Car with 350/manual/AC. I have been running the car with the carb it came with - a Holley 4 barrel. My son got me an original correct numbers matching Quadrajet 4MV and he rebuilt it.
It is missing the hot idle compensator components. Where can I buy these parts? GM dealer?
Old 10-03-2014, 07:26 AM
Not all Quadrajets had the compensator, even though it would have the boss machined into the body, but not drilled through.
But if you're not building a down to the last correct nut & bolt restoration, you can block off the opening on the carb.
Have you tried looking on ebay?
And just to make sure, you're referring to the hot idle vent in the back of the carb, and not the idle vent valve on the top cover.
santa6
09-29-2014 11:11 AM
B.M.
70-81 V8 Tech
04-10-2010 06:33 AM
mtn_maro
10-25-2009 06:34 PM
Ejam
08-18-2009 06:55 PM
WayFast84
02-25-2006 11:00 PM
Quick Reply: Quadrajet 4MV Hot Idle Compensator
