Pace Car won't Pace
Old 09-20-2014, 10:37 PM
Z28/302's Avatar
Make sure you have the correct thermostat, 195 degrees. A lower temperature thermostat (or no thermostat at all) will make it run hotter, not cooler, because the water doesn't stay in the radiator long enough to cool.
Old 09-21-2014, 07:08 PM
No thermostat is not good because of the flow rate. But just because a thermostat opens a little sooner (165 stat) has no effect on the cooling capability of a system. Old racers trick is to just put in a restrictor plate to slow things down. Also racing water pumps have lower flow rates at higher RPMS.
The flow being to fast is a function of high RPMs. A car without a thermostat sitting at idle is not going to flow water so fast it can not cool. Anyone who has been forced to go with no thermostat for a week in the north knows it is tuff to even get the water warm enough to defrost your windshield at idle. A motor running a 6500 RPMs for extended amounts of time can have issues.
Old 09-21-2014, 07:15 PM
Originally Posted by santa6
The one thing I did do periodically was pull the spark plugs every so often and spray oil in each cylinder and turn it over with a wrench on the pulley/balancer
No need to do this more then once. Even then its risky. If you don't get all the oil out you risk hydro locking the motor. That would put a lot of stress on the piston, rods and rod bearings and could cause major internal damage to the motor.
Old 09-28-2014, 01:12 PM
santa6's Avatar
Default Back to Cooling
All, we had the radiator re-cored for $600. Have had it blasting up and down the highway in 85 degree temps and it just barely gets to a quarter on the console temp gauge. Problem solved. Thanks all the thoughts and help.
JRalston
04-14-2014 09:34 AM
Flash Mobster
03-08-2010 02:11 PM
whits_iroc
10-27-2009 04:29 AM
209mac
03-01-2008 08:32 PM
mentalward
11-16-2006 06:27 PM
Quick Reply: Pace Car won't Pace
