Mini Starter Heat Shields
Ceramic Headers
I ended up wrapping my steel headers just to reduce the heat in the engine bay, but not everybody likes that look. Because I wrapped my headers, I didn't need a standard heat shield for my high torque starter, but the shields look kinda cool and is fairly simple to install.
So, your saying you don't like the mummy effect
ha ha J/K
I do have a friend that has a nice set of ceramic headers that look pretty nice, and work great. He doesn't have a heat shield on his starter and his starter is working fine for the past few years.
Of course, the standard heat shield is a little less costly
ha ha J/K
thermatec has some good stuff. im using one of these after the first starter went to the happy starting grounds. also switced from tufstuf to powermasster
Thermo-Tec : Starter Heat Shield
3 or 4 months now, all though summer. there is a opening in the front that seems like it would let air though. first starter only lasted a month before problems started. stater still worked when i took it out a couple months later but i had to click it a bunch some times. i think the heat cooked the solonoid.
