Need advice on alternator bracket.
Old 01-14-2014, 03:59 PM
Milan's Avatar
Default Need advice on alternator bracket.
Small block, short water pump with power steering. I installed a tunnell ram intake but there is no boss for the alternator bracket. There is no holes in the heads. I cant seem to find any setup that will allow for a alternator. Any suggestions?
Thanks
Old 01-14-2014, 05:18 PM
You're talking about the upper bracket I take it. You can connect to the upper water pump mounting bolt, with a bracket like this:
Old 01-14-2014, 08:03 PM
Everett#2390's Avatar
Sixty-six and earlier SBC's used the long bracket from the w/pump bolt.
W/pump bolt is a double studded bolt.
Old 01-14-2014, 08:07 PM
Milan's Avatar
I cant see the image, it just has a red x. Also the bracket has 1 bolt that goes in the water pump and 1 that goes in the intake which my intake doesnt have.
Old 01-14-2014, 08:09 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
you can drill and tap the head for the threads. just find a head with holes to measure so it goes in the right spot
Old 01-14-2014, 08:10 PM
Milan's Avatar
Old 01-15-2014, 08:46 AM
Here's what I've used on numerous builds. It's less than $15 for the two pieces at Summit, and works with long or short water pumps. Chrome too! Works with headers or stock exhaust manifolds on the front exhaust port bolts.
http://www.summitracing.com/parts/sum-g4050/overview/
http://www.summitracing.com/parts/sum-g4051/overview/
Old 01-15-2014, 09:23 AM
Milan's Avatar
Thanks for the suggestion, unfortunately this bracket http://www.summitracing.com/parts/sum-g4051/overview/ bolts to the head. My head doesnt have any bolt holes.
Old 01-15-2014, 09:26 AM
I presume you already have the alternator hanging on a lower bracket, which is what those two ^ are. This is the upper bracket that was in the picture you couldn't view: http://www.summitracing.com/parts/spe-42263/overview/
Old 01-15-2014, 09:37 AM
Milan's Avatar
Ok, I got it now. Sometimes it takes me a while to get it. Its hell getting old. Thank you all for the help.
Quick Reply: Need advice on alternator bracket.
