Gen light stays on
Old 04-24-2015, 11:55 AM
RS67RS's Avatar
Default Gen light stays on
I recently removed the generator and installed a 100A alternator now the GEN light stays lit when the car is running. It was not on before the swap. Is this due to the increased power of the new alternator?
Old 04-25-2015, 12:22 PM
Typically the Gen lamp goes on when the current flowing out of the battery exceeds the current flowing out from the generator. May want recheck your installation making sure the same type generator was installed.
Old 04-27-2015, 05:48 AM
Everett#2390's Avatar
You said 'Generator', is the vehicle '61 or older?
If you swapped in a alt in place of a gen, you will have to rewire the charge circuit for the alternator.
If the 'gen' is an alt, did it work before swapping out?
Picture of new alternator?
Craig Ferguson
04-15-2013 12:49 AM
shaione
02-27-2013 07:15 PM
shaione
11-19-2012 10:27 AM
johnnie72
03-04-2012 07:50 PM
Lackey
82-92 V8 Tech
05-25-2007 08:28 AM
Quick Reply: Gen light stays on
