Engine Oil Leak
make sure it is not from the back of the valve cover or the intake running down behind the block
if it is your rear seal remove the pan or pull the engine (depending on type of oil pan you have) and replace
g3mini609
12-26-2009 06:21 AM
ChaoticBastard
05-09-2006 02:01 AM
