Drum-to-Disc brake Conversion Kit for a Classic Camaro
If you are looking to convert drum brakes to disc brakes on your classic Chevy Camaro, you should definitely check out the conversion kit by Right Stuff.
Each kit is model specific and includes pretty much all required components for a brake upgrade, so you can conveniently install it in your own garage.
Right Stuff® - Drum-to-Disc Conversion Kit
*Image may not reflect the product.
Available options:
- Rear+2 Disc Kit
- With 0" Drop Spindles
- With 2" Drop Spindles
- Without Spindles
Alternatively you can convert to discs just the front brakes.
This option will be available in the drop down on the page with the kit.
Please let me know if you need a quote - I will be glad to calculate it for you!
Which Disc brake conversion kit do you prefer?
- Front disc brakes / Rear Drums
or
- Front and rear Disc brakes
Available options:
- Rear+2 Disc Kit
- Without Spindles
or
Vdubwardo
02-17-2012 04:27 PM
