Brake pedal question....
Old 04-07-2011, 01:46 PM
A1CAMARO's Avatar
Default Brake pedal question....
I have a '67 Camaro with a 383 stroker. I installed the Summit front disc brake kit (with booster/master cyl). The pedal was low and due to my cam I was advised to put in a vacuum pump. Put the pump in, pedal was inconsistent. Then I put a vacuum canister in and now the pedal is waaaay to firm. I have serviced the rear brakes, and bled the system multiple times. I am not sure what to do at this point.....
Old 04-07-2011, 06:03 PM
yzair's Avatar
Did you replace the push rod to one for power brakes and did you remove the rubber boot over push rod.
Old 04-07-2011, 07:13 PM
A1CAMARO's Avatar
Yes, I replaced the rod and removed the bushing. It worked ok after the pump went on, but was not consistent pedal. Then, I put the vacuum tank on and the pedal became rock solid.
Old 04-08-2011, 06:12 PM
brunk5's Avatar
Are your rear brakes drum or disc? Do you have the correct valve installed?
Old 04-08-2011, 11:31 PM
A1CAMARO's Avatar
The rear brakes are drum. I have replaced the wheel cylinders, shoes and drums (one drum had a flat spot on the outside, I'm guessing the wheel came off when it was owned by the previous owner). I'm told the new valve (came with the kit) is the correct one for a front disc/rear drum setup.
Old 04-08-2011, 11:43 PM
brunk5's Avatar
What kind of canister did you install? Does it have a check valve?
Old 04-12-2011, 09:39 AM
A1CAMARO's Avatar
Brunk, thank you for your questions and help. I removed the canister and adjusted the valve on the pump all the way up. Looks like they are working great! I will post some "smokey" pics when I can!
darthtater
03-06-2021 08:03 PM
jeffj1941
10-25-2010 01:39 PM
Thoreau
08-13-2010 05:10 AM
jasunf
05-03-2010 10:46 AM
Quick Reply: Brake pedal question....
