battery drain problem
Old 10-19-2014, 12:58 PM
santa6's Avatar
Well, it's been a while on this subject - shows how often I have time to mess with this car. Since the last post on this thread, I have dealt with a cooling problem and got it resolved with help from this forum(re-cored the radiator). My son got me a numbers matching correct Rochester 4MV carb and I installed that recently. Also a few other minor items. Also during the time away, I just recently replaced the battery.
I took it out for a spin this morning. It's idling a bit high so I need to adjust that. The alternator light never came on and while running down the road, the console amp gauge is reading 5 amps - one notch off of zero. Then while driving about 60mph I turn on the headlights and heater fan full. The gauge goes to zero - back to 5amps when I turn everything off.
So, what should that gauge be reading when your running down the road? SHould it go to zero under load like that?
  #22
Old 10-19-2014, 01:39 PM
You could put a clamp ammeter on the output wire of the alternator, if the meter shows high current, but the voltage stays low then there is an overload somewhere.
  #23
Old 10-25-2014, 10:40 AM
santa6's Avatar
Okay, but can anyone tell me what the console amp gauge should read?
  #24
Old 10-25-2014, 11:02 AM
When running and battery is fully charged, the gauge should be at 0 or slightly on the + side. Right after starting, or when other loads are on the battery, the gauge will read heavier into the + side.
As long as the needle is on the + side, your charging system is working.
frmjersey
02-12-2009 05:29 PM
jpucci
08-19-2007 08:56 PM
jpucci
07-17-2007 09:54 PM
86 camaro
06-08-2007 01:28 AM
Tom97V6
04-07-2006 06:40 PM
Quick Reply: battery drain problem
