Back seat removal - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
LinkBack Thread Tools Search this Thread
Old 01-19-2012, 08:08 PM
Chevynutz's Avatar
Default Back seat removal
Does anyone know the steps to remove the rear seat in a 68 ?
Thanks in advance
Old 01-19-2012, 08:12 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
the bottom comes out first u lift up on it then out. I know that for sure i think the back you push up on it and it slides up then out. i dont think there is any bolts? ive only had the bottom out of mine.
Old 01-19-2012, 08:58 PM
The bottom cushion comes out first. You have to push the front of the bottom cushion down slightly and then backwards, toward the trunk. Pushing the lower cushion usually requires a good amount of force. You really have to get in the car, on the hump, facing the rear of the car and push back on the lower cushion with one hand on each side. You feel the the bottom of the seat frame clear the two brackets that hold it down. Then lift up. If you cleared the bottom brackets correctly, it is easy to pull the seat up. Once the bottom cushion is out, look at the bottom of the top cushion. There is a tab, a thin piece of metal, that extends from the floor that passes thru a slot at the bottom of the top cushion's frame. This tab is usually bent over. Simply straighten it out, then pull the bottom of the top cushion toward the front of the car. Only enough to clear the tab, then lift the cushion straight up.
Old 01-20-2012, 06:12 PM
Chevynutz's Avatar
Default back seat
Thanks guy's , i will check it out ! In the staging lane WOO/HOO !!!
Old 01-21-2012, 09:40 AM
StoveBolts's Avatar
Yeah, sometimes getting the back seat out can be very frustrating! The seat is secured by two hooks that the wire frame of the seat "snap" into. I'm only a buck fifty, so I push the front seats as far forward as they will go and then on the lower portion of the backseat, right behind (and center) of the front seat I'll push down and away to get the seat unhooked from it's hook.
If you get a light, you can see where the seat hooks into the body. Makes it easier to know what your unhooking! Sometimes they pop right out and other times they just want to be stuborn.. but they always seem to come out easier than they go back in lol!
Good luck!
Old 01-22-2012, 08:19 PM
thefley's Avatar
December 2012 Ride of the Month
Back seat is a pain, it is so much easier if you pull the front seats out first. (only 4 bolts each) this gives you more room. if you feel around on both sides you can feel the clip the spring/wire catches on. at this point, I just gave the seat a good kneeing at this point and pulled up at same time. then do same on other side. simple this way, others like tools and hammer but the kneeing works great.
Reply
Thread Thread Starter Forum Replies Last Post
seat removal wesman98 82-92 Interior 1 09-01-2013 10:08 AM
Rear seat Removal ? yzair 67-69 General 1 04-07-2011 07:09 PM
Seat removal Ceelo912 93-02 General 6 07-27-2010 10:52 PM
Removal of 69 Rear Seat 69 Conv 67-69 General 2 04-09-2010 09:50 PM
Rear Seat Removal HaloNick 82-92 General 3 11-16-2005 12:33 PM
Tags
2010, 2011, 2012, 68, back, backseat, bottoms, camaro, forum, rear, removal, removing, rs, sear, seat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
